The difference between UFACTORY xArm5, xArm6 and xArm7 ​
The purpose of this article is to describe the differences between UFACTORY xArm5, xArm6 and xArm7.
1. Specifications ​
SPECIFICATION
xArm 5 LitexArm 6xArm 7
Payload(kg)3kg5kg3.5kg
Reach(mm)700mm700mm700mm
Degrees of Freedom567
Maximum Speed(m/s)1m/s1m/s1m/s
Weight(kg, body only)11.2kg12.2kg13.7kg
Maximum Speed180°/s180°/s180°/s
Joint1±360°±360°±360°
Joint2-118° ~ 120°-118°~120°-118°~120°
Joint3-225°~11°-225°~11°±360°
Joint4-97°~180°±360°-11°~225°
Joint5±360°-97°~180°±360°
Joint6±360°-97°~180°
Joint7±360°
2. Motion Characteristics ​
  • Cartesian control
xArm 5 Lite: Due to the robot configuration,the actual flexible degreesof freedom of linear and circular motions in Cartesian space is 4, which is [x, y, z, yaw], similar to a SCARA manipulator with four degrees of freedom. Before initiating Cartesian control movement, it is necessary to ensure that the end flange surface of xArm5 and the base are completely parallel. If mounted on a horizontal plane, the roll and pitch should be [± 180 degrees, 0 degrees], otherwise the trajectory is likely to have no solution.
How to align the tool end flange of xArm 5 Lite?
