How to solve C31 error? ​
UFactory version: V2.1.0+
When the actual obtained current exceeds the expected current threshold, our software will report a C31 error and stop the arm to protect it.
There are 4 reasons, please check the configs below to solve it.
1. TCP payload ​
Check if the TCP payload setting on 'Settings-Motion-TCP' is consistent with the actual payload.
2. High motion speed ​
Try to lower the speed to verify this problem.
3. Friction parameter ​
Check if the friction parameter is loaded successfully.
You can enter 'Settings-My Device-System Info-Robot SN', if the SN info is consistent with the SN attached to the robot base, if so the friction parameter is loaded successfully.
4. Collision sensitivity ​
Try to lower the 'Settings-Motion-Parameters-collision sensitivity' to verify this problem.
Note: If there are still problems, please provide the information above to the support team.
