UFACTORY Robotic Arm with Dexterous Hand RH56DFX ​
Project Overview ​
This project demonstrates an application based on the UFACTORY robotic arm and the INSPIRE-ROBOTS dexterous hands RH56DFX series.
Users can quickly control the dexterous hand via UFACTORY Studio software, implement fast grasping and other applications.
The following videos show the dexterous hand grasping eggs and oranges, drilling cardboard with an electric drill, and controlling a computer mouse to switch web pages.
Watch the video
Hardware Requirements ​
  • Robotic Arm: UFACTORY- 850, xArm series (version 1305)
  • Dexterous Hand: Inspire Robots - RH56DFX-Left / RH56DFX-Right
Hardware Connection ​
Robotic Arm End Effector Definition ​
  • Plug in Connection
PinColorSignalPinColorSignal
1Brown+24V (Power)7BlackTool Output 0 (TO0)
2Blue+24V (Power)8GrayTool Output 1 (TO1)
3White0V (GND)9RedTool Input 0 (TI0)
4Green0V (GND)10PurpleTool Input 1 (TI1)
5PinkUser 485-A11OrangeAnalog Input 0 (AI0)
6YellowUser 485-B12Light GreenAnalog Input 1 (AI1)
  • Contact Connection
RH56DFX Dexterous Hand Definition ​
Note:
The robotic arm end and the dexterous hand cannot be directly connected. Please contact Inspire Robots for an aviation adapter connector.
Control Methods ​
UFACTORY Studio Control ​
UFACTORY Studio Version: ≥ V2.7.0
1. Real-Time Control Interface ​
Select INS-RH56DFX-Left or INS-RH56DFX-Right.
A pop-up will ask to set the robotic arm baud rate to 115200.
Adjustable parameters: position, force, speed.
2. TCP Settings ​
Go to Settings - Motion Parameters - TCP Settings, then select INS-RH56DFX and save.
3. Blockly Control ​
Blockly provides two blocks for the dexterous hand, allowing control of either the entire hand or individual fingers.
Optional parameters:
  • Finger: Little finger, Ring finger, Middle finger, Index finger, Thumb Flexion, Thumb Rotation, Entire hand
  • Position: 0–1000
  • Speed: 0–1000
  • Force: 0–1000
  • Wait option: Whether to wait for the current command to finish before sending the next (synchronous or asynchronous)
Python SDK Control ​
1. Set UFACTORY Robotic Arm End Baud Rate ​
code = arm.set_tgpio_modbus_baudrate(115200)
2. Perform 485 Communication ​
code, res_data = arm.getset_tgpio_modbus_data(modbus, timeout=100)
Example: set_yinshi_rh56_gripper.py
