How to solve C24 error? ​
UFactory version: V2.1.0+
There are 2 reasons for C24 error:
  1. The motion speed(calculated joint speed) is too high.
  2. Singularity appears in the motion path.
1. Reduce TCP speed ​
Reducing TCP motion speed/acceleration/jerk in the program.
2. Re-plan the path to the target point(Interpolation) ​
3. Bypass singularities ​
  1. UFACTORY Studio: Settings-General-Advanced Settings-Bypassing Singularities.
  2. Python SDK: set_allow_approx_motion(self, on_off)
Example ​
  1. Reduce TCP Speed
  2. Re-plan the path
  3. Enable 'Bypassing Singularities'.
Note: If the above methods can not solve your issue, please send the files below to the support team.
  1. The firmware and UFactory Studio version.
  2. The script or points(>2) that can reproduce the problem.
  3. The configuration file. It can be downloaded in 'Settings-General-Advanced Settings-Logic-Export the configuration file'.
