0.1 mm Displacement Test for 850 and xArm 6 ​
Measurement Method ​
  • Each robotic arm starts from the specified initial position and moves in the X+, Y+, and Z+ directions with 0.1 mm step commands, repeated 40 times. A 3-second wait is applied after each movement.
  • The actual movement distance is continuously measured by a Keyence GT2 contact-type digital sensor at a sampling frequency of 20 HZ.
Test Conditions ​
The test is conducted at room temperature with a payload of 0 kg on the robotic arm.
Robot Models and Initial Positions ​
ProductModelDirectionInitial Position
xArm 6XI1305X+[298, 0, 200, 180, 0, 0]
xArm 6XI1305Y+[300, -2, 200, 180, 0, 0]
xArm 6XI1305Z+[300, 0, 198, 180, 0, 0]
850FX8510X+[298, 0, 200, 180, 0, 0]
850FX8510Y+[300, -2, 200, 180, 0, 0]
850FX8510Z+[300, 0, 198, 180, 0, 0]
XYZ Movement Error ​
xArm6 XYZ Error ​
xArm6 XYZ Error
850 XYZ Error ​
850 XYZ Error ​
XARM6 ​
X Axis ​
xarm6_x_errorxarm6_x_box
Y Axis ​
xarm6_y_errorxarm6_y_box
Z Axis ​
xarm6_z_errorxarm6_z_box
850 ​
X Axis ​
850_x_error850_x_box
Y Axis ​
850_y_error850_y_box
Z Axis ​
850_z_error850_z_box
Raw Data ​
Raw Data Download: Click Here
