Guide to run robotic arm at the maximum speed? ​
Take xArm Series as an example.
Firmware version: v2.0.0+
UFactory Studio version: v2.0.0+
xArm-Python-SDK version: v1.10.0+
1. Parameter Adjustment ​
The main parameters that affect the movement speed of xArm are: speed, acceleration, and jerk.
TCP MotionJoint Motion
Speed1000mm/s0 ~ 180°/s
Acceleration50000mm/s²1146°/s²
Jerk100000mm/s³28647°/s³
It is recommended to adjust the jerk to the maximum, which will speed up the motion of robotic arm.
  • Parameter adjustment via UFACTORY Studio
'Settings-General-Advanced Settings-Parameters'
  • Parameter adjustment via Python SDK
1) Speed: 'speed' parameter
2) Acceleration: 'mvacc' parameter
3) Jerk: set_tcp_jerk() , set_joint_jerk()
//code example
arm.set_tcp_jerk(100000)
arm.set_joint_jerk(28647, is_radian=True)
arm.save_conf()
2. Motion Planning ​
Adjust Parameters to do continuous motion.
  • radius > 0
  • wait = False
Example:
Radius>0, wait=False; Video: https://youtu.be/oX_J8RplEw4
Radius>0, wait=True; Video:https://youtu.be/wpBzt3a30L0
Radius<0, wait=False; Video:https://youtu.be/pi-5PPhPpfg
