How to solve S17 error? ​
S17: Single-turn Encoder Error
UFactory version: V2.4.0+
Status code=16 ​
Lite6, xArm ≤1303 version ​
Code:S17 , Joint ID: *(can be 1~7) , status code:16 , (only for Lite6) servo version < 4.0.18.
  1. press down the E-stop button and then release.
  2. Enter 'Settings-General-Debugging Tools-Joing', send H101 D0104 V1 I* to unlock joint*, manually move joint* a little bit (Note: For Lite6, it is recommended to rotate joints 4, 5, or 6 by at least 45°), and then send H101D0813V2I* , press down E-stop button. (This step will reset the zero position, so you need to mark the zero position of joint* before moving)
  3. release the E-stop button, move Joint* to the zero position, send D13 I* , press down E-stop button.
  4. Try to enable the robot again.
850,Lite6, xArm ≥1304 version ​
Code:S17 , Joint ID: *(can be 1~7) , status code:16, (only for Lite6, xArm1304) servo version ≥ 4.0.18
  2. Download and launch xarm-tool-gui, Enter the controller IP address and click Connect.
  3. (only for Lite6, xArm1304; skip this step for other version) check the servo version is ≥ 4.0.18.
  4. Switch to the ApiTool tab, select the faulty Joint ID, and click Clear Single-turn Status Code 16.
  5. Press the Emergency Stop (E-Stop) button, wait for 5 seconds, then release it. Try to enable the robotic arm again.
