Guide to use digital IO ​
There are 2 difference IOs of controller and end effector.
  • Controller: 8/16 digital input, 8/16 digital output, 2 analog input, 2 analog output.
  • End effector: 2/5 digital input, 2/5 digital output, 2 analog input
1. Controller IO(xArm1300/850/Lite6) ​
1.1 Digital Input ​
  • CI0~CI7
  • DI0~DI7
It's high level by default, 0-5V is low level, 18-30V is high level.
1.2 Digital Output ​
  • CO0~CO7
  • DO0~DO7
It's an OC output, NPN output, the current is 100mA.
2. End Effector IO ​
2.1 Digital Input ​
  • TI0
  • TI1
  • TI2, TI3, TI4(UF850)
It's low level by default, the voltage is 0-30V, 1.6-30V is high level.
2.2 Digital Output ​
  • TO0
  • TO1
  • TO2, TO3, TO4(UF850)
3. Case ​
Purpose: Amplify the output current by adding PMOS Module.(Also applicable to COx/DOx)
Application: Drive Relay
  • Input Voltage: 3-24V; Current: 5mA.
  • Output Voltage: 5-36V; Current: 5A, if it exceeds 5A, need to add a heat sink, and can't exceed 20A.
Connection:
  • Signal V+ to 24V
  • Signal V- to TOX
  • DC to 24V
  • DC to GND
  • load V+ to OUT+
  • load V- to OUT-
