How to verify the digital input and output are normal? ​
Take TO and CI as an example.
1. Hardware Connection ​
Connect TO0 to CI0, Connect TO1 to CI1
Connect the End-Effector cable to the end side of the arm.
Connect the pin module back to controller's IO.
2. Software Operation ​
1) Enter 'Settings-Externals-Controller IO', CI0 & CI1 should in 1(high level).
2) Switch to 'Robot IO', set TO0 & TO1 to 1(high level).
3) Go back to 'Controller IO', CI0 & CI1 should be changed to 0(low level).
