How to install UFACTORY Studio in Docker ​
Implemented via docker: Control simulated UFACTORY robots in UFACTORY Studio without the need for a real robot arm!
Preparation:
If you follow the guidance, you will start the xArm 6 robot by default.
1. Get the docker image ​
docker pull danielwang123321/uf-ubuntu-docker
2. Create and run container ​
  • include web simulation and SDK ports(Recommend)
docker run -it --name uf_software -p 18333:18333 -p 502:502 -p 503:503 -p 504:504 -p 30000:30000 -p 30001:30001 -p 30002:30002 -p 30003:30003  danielwang123321/uf-ubuntu-docker
  • only use UFACTORY Studio web simulation(Not recommend)
docker run -it --name uf_software -p 18333:18333 danielwang123321/uf-ubuntu-docker
3.Run the xArm robot firmware and UFACTORY Studio ​
/xarm_scripts/xarm_start.sh 6 6
Note: The 6 6 means xArm 6, restarting the container choose the robot according to your preferences:
5 5, xArm 5
6 6, xArm 6
7 7, xArm 7
6 9, Lite 6
6 12, 850
4. Access the UFACTORY Studio ​
Run a web browser and input 127.0.0.1:18333 or locathost:18333
If there is a prompt of “Unable to get robot SN …” comes out on the web simulation page, click “Close" and then you can use the web simulation.
If you need to use xArm SDK
If you need connect the simulated robot and run your codes in your host computer, for example running your python codes, change the IP address to 127.0.0.1 and run.
5.Run the “Blockly-to-Python” codes with external IDE like VSCode or Pycharm ​
In case you copy the “Blockly-to-Python” codes from the internal Python IDE and run in the external IDE like VSCode or Pycharm on your computer, make sure add “check_joint_limit=False” in the line of instantiation like this
arm = XArmAPI('127.0.0.1', baud_checkset=False, check_joint_limit=False)
Note:
1-Test under Ubuntu 24.04 x86-64 and Windows 11 x86-64
2-Some uesfull commands
//Show the running container
  docker ps
//Stop the running container
  docker stop <container ID or container name >
//Start the container ''uf_software"
  docker start uf_software
//Enter the shell of the container “uf_software”
  docker exec -it uf_software /bin/bash
Release notes ​
2025.2.5
1.Add methoed of running “Blockly-to-Python” codes with external IDE like VSCode and Pycharm.
2.Modify the commands for Linux Ubuntu 24.04 x86-64
